Here is the log message:
Warning(115005): Unlicensed IP: "CXL IP for Device Type3 with DDR4 based MemBuffer (6AF7 0188)"
Warning(115004): Unlicensed encrypted design file: "/home/fpga/Desktop/sample/intel_rtile_cxl_top_0_ed/hardware_test_design/qdb/_compiler/cxltyp3_memexp_ddr4_top/auto_fab_0/24.3.1/final/1/netlist.model"
Warning(115004): Unlicensed encrypted design file: "/home/fpga/Desktop/sample/intel_rtile_cxl_top_0_ed/hardware_test_design/qdb/_compiler/cxltyp3_memexp_ddr4_top/auto_fab_0/24.3.1/final/1/names.model"
Warning(115004): Unlicensed encrypted design file: "/home/fpga/Desktop/sample/intel_rtile_cxl_top_0_ed/hardware_test_design/qdb/_compiler/cxltyp3_memexp_ddr4_top/root_partition/24.3.1/final/1/netlist.model"
Warning(115004): Unlicensed encrypted design file: "/home/fpga/Desktop/sample/intel_rtile_cxl_top_0_ed/hardware_test_design/qdb/_compiler/cxltyp3_memexp_ddr4_top/root_partition/24.3.1/final/1/names.model"
Error(23714): Can not generate programming files for your current project because you do not have a valid license. Visit the Intel FPGA Self-Service Licensing Center at https://licensing.intel.com
but in the **tools**->**License setup**, I do have the license for this ip: 6AF7 CXL IP for Device Type 3 with DDR4 based MemBuffer (0118)
How long ago did you generate the license file? You may want to try generating it again. I recall there were file generation issues in the November/December timeframe.
Thank you for replying. I just generated the license in less than a month.
Can you answer Steven's question?
regards,
Farabi
You have generated the license, but still can't compile the IP?
regards,
Farabi
Topic Options
