21598 Discussions
Asynchronous Set Registers - Cyclone III
I am examining an IP Core for use within a Cyclone III LS. It notes that it is necessary to have asynchronous set and resets on the registers implemented in the FPGA. I am pretty sure asynchronous resets are available in the Cyclone III, but are asynchronous sets?
Thanks!
The FPGA registers only have asynchronous resets, but the software can emulate an asynchronous set by using a not push back.
However, this means you can only have either an asynchrnous set or an asynchrnous reset in a register. You can't have them both on the same register.
You can't also have a register initialized to 0 with an asynchronous set or, vice-versa, a register initilized to 1 with an asynchronous reset.
Ah, so one or the other, but not both?
Hmm, since there's no work-around, I'll see if I can figure out why the IP Core needs these signals to be asynchronous.
Tr this:
process(set,reset,clk) begin if reset = '1' then data_out <= (others => '0'); elsif set = '1' then data_out <= (others => '1'); elsif rising_edge(clk) then data_out <= data_in; end if; end process;
