21595 Discussions
Shift out design within state machine
Greetings.
I have a questions I cannot find in any books.
I have several binary sequences I need to shift out in a shift register. there are seven of them ranging from 24 bits to 48 bits. They are basically error codes I am using to flash an LED in a specific pattern.
I am writing a case statement that uses an 8 bit number as an input, clocks it in and then analyzes it. Once the binary number is determined it moves to the state and clocks out a specific sequence of 1's and 0's a half a second per bit.
The problem is that the bit streams are all different length and I am trying to think of a creative way to output a different length binary stream. Worst case I could make a state machine for every single binary output but this would use a lot of logic elements up. Are there any other methods to shift out binary sequences of varying lengths within a state machine or a case statement?
Thank you
Whatif you choose longest length for a shift register. Insert your bits into the shift register starting from one end. Then enable shift for the number of bits that you inserted.
Kaz's idea would probably be the simplest.
But could not use the input number as the load value for a down counter?
--- Quote Start ---
--- Quote End ---
Page 45 has an example that may work for you too:
http://www.ovro.caltech.edu/~dwh/carma_board/ad9956_tests.pdf
Cheers,
Dave
