21602 Discussions
Atom X is connected on its PADTOINPUTREGISTERDELAYSETTING port but atom Y is not.
Hi all, first time poster here.
I'm not an Altera guru, by any means, but I've been able to muddle through with the help of Google and co-workers. This error has me baffled, though.
I am trying to include a DRR3 phy created by the mega-wizard plugin manager in our design, and I get the following error:
Error: Atom "...|ddr3_phy_alt_mem_phy_dq_io:dqs_group.dq.dq_pad|ddr_io_config_gen.dq_io_config" is connected on its PADTOINPUTREGISTERDELAYSETTING port but atom "...|ddr3_phy_alt_mem_phy_dm:dqs_group.dm_gen.dm_pad_gen.dm_pad|dq_io_config" is not connected. Both must be connected or both must be disconnectedNow, I've looked in the verilog (alt_mem_phy.v) created by the plug-in manager, and I've found the ports that it's complaining about:
begin : ddr_io_config_gen // IO_CONFIG - num_dq 0->16 stratixiii_io_config dq_io_config( .datain (scan_din), // shared per DQS group .clk (sc_clk), .ena (scan_enable), .update (scan_update), // shared per DQS group // synopsys translate_off .devclrn(), .devpor(), .dutycycledelaymode(), .dutycycledelaysettings(), .outputfinedelaysetting1(), .outputfinedelaysetting2(), .outputonlydelaysetting2(), .outputonlyfinedelaysetting2(), .padtoinputregisterfinedelaysetting(), // synopsys translate_on .padtoinputregisterdelaysetting(dq_padtoinputregisterdelaysetting), .outputdelaysetting1 (dq_outputdelaysetting1), .outputdelaysetting2 (dq_outputdelaysetting2), .dataout (scan_dout) ); endand
// IO_CONFIG - num_dq 0->16 stratixiii_io_config dq_io_config( .datain(scan_din), // shared per DQS group .clk(sc_clk), .ena(scan_enable), .update(scan_update), // shared per DQS group // synopsys translate_off .devclrn(), .devpor(), .dutycycledelaymode(), .dutycycledelaysettings(), .outputfinedelaysetting1(), .outputfinedelaysetting2(), .outputonlydelaysetting2(), .outputonlyfinedelaysetting2(), .padtoinputregisterfinedelaysetting(), // synopsys translate_on .padtoinputregisterdelaysetting(), .outputdelaysetting1(dq_outputdelaysetting1), .outputdelaysetting2(dq_outputdelaysetting2), .dataout(scan_dout) );So it's pretty clear that one .padtoinputregisterdelaysetting port is connected and the other one isn't, but when I try to disconnect the connected one, the error doesn't go away.
Any help on this? Thanks in advance!
