Programmable Devices
21602 Discussions
Autostart NIOS from external SDRAM problem
Oliver_I_Sedlacek
Nouveau contributeur III
6 604 Visites
So my NIOS code has outgrown the available on chip RAM and I've moved it to off chip SDRAM. Very slow, but I fire up Eclipse and I can get it to run. I need to get it to run automatically and I've found snippets of information by perusing the NIOSII software developers Handbook but can anyone point me to definitive documentation. I know I need to persuade the compiler to produce a ROM image that becomes a MIF, which I believe it does, and get something (maybe a bootloader) to do the initialisation, and somewhere I need to tell the tools to run that code.
Can anyone help with the blanks?
Étiquettes (1)
0 Compliments
36 Réponses
EBERLAZARE_I_Intel
4 543 Visites
Please check this page, and let me know which method would you like to go for?:
https://www.intel.com/content/www/us/en/docs/programmable/683689/current/processor-booting-methods.html
0 Compliments
Oliver_I_Sedlacek
4 535 Visites
Aha, so I was looking in the wrong manual!
Well I've chewed my way through the instructions and as I expected my NIOS neither runs nor can I debug it from Eclipse. The manual does not list any steps for diagnosing faults, so where do I go from here?
0 Compliments
EBERLAZARE_I_Intel
4 500 Visites
Apologies I came back a bit late, for debugging it is on chapter 6.
0 Compliments
Oliver_I_Sedlacek
4 495 Visites
I've read chapter 6 and none of it really sheds any light on my problem. My system runs perfectly and the code has been debugged, so I suspect vector offsets are broken but I don't know how to inspect them if I can't connect the debugger.
0 Compliments
EBERLAZARE_I_Intel
4 470 Visites
Could you provide your design example? Or is your example similar to any of the booting methods in the Embedded Handbook?
0 Compliments
Oliver_I_Sedlacek
4 459 Visites
The intent was to go with application code stored in EPCQ flash and the run time location is external RAM as per Table 33 and section 5.2.3.4 of the Embedded Design handbook. The SOF is 802 kB in size so I just rounded up to make the offset to the HEX 1024 kB.
As I stated earlier, everything works if I load the application from the Eclipse debugger, but I do need it to run from power up.
I've added a project archive, all done in Quartus 20.1 Lite.
0 Compliments
EBERLAZARE_I_Intel
4 433 Visites
I think I got it what you intend to do, let me work on it and get back to you.
0 Compliments
Oliver_I_Sedlacek
4 423 Visites
0 Compliments
EBERLAZARE_I_Intel
4 360 Visites
You could do the programming using .jic:
https://www.intel.com/content/www/us/en/docs/programmable/683689/current/programming-96050.html
With programming using .jic, you can reset your FPGA device using the reset button or power cycle your hardware and it will run upon power up. Is this what you are trying to achieve?
0 Compliments
Oliver_I_Sedlacek
4 350 Visites
The FPGA configures fine from power up (programmed via .JIC as suggested). The problem is the NIOS doesn't boot. I've been following  Table 33 and section 5.2.3.4 of the Embedded Design handbook but I'm obviously doing something wrong, but can't diagnose what.
0 Compliments
EBERLAZARE_I_Intel
4 323 Visites
I cannot find any major differences in your design. Have you tried to use the example in the document and start from there? :
https://www.intel.com/content/www/us/en/docs/programmable/683689/current/reset-and-exception-vector-settings.html
0 Compliments
EBERLAZARE_I_Intel
4 247 Visites
Any update?
0 Compliments
Oliver_I_Sedlacek
4 191 Visites
Trying to go round the loop again and I'm stumped as the EPCQ isn't offered in the reset vectors memory drop down. I don't remember this as a problem earlier, but then that might just be my memory. Screenshot attached.
0 Compliments
Oliver_I_Sedlacek
4 234 Visites
You seem to just have pointed me at the online version of the document that I was following anyway, so no progress.
0 Compliments
EBERLAZARE_I_Intel
4 181 Visites
The link that I shared have the hardware design for Quartus for you to follow the steps, and shows you the connection that is needed to be made to have it as Reset Vector for Excecute In Place. Maybe you can try the pdf versions and check the 5.2.3.3 Chapter.
0 Compliments
EBERLAZARE_I_Intel
4 168 Visites
Can you check the connection made as per the 5.2.3.3 Chapter:
https://cdrdv2-public.intel.com/666980/edh_ed_handbook-683689-666980.pdf
0 Compliments
EBERLAZARE_I_Intel
4 129 Visites
Any update?
0 Compliments
Oliver_I_Sedlacek
4 074 Visites
So two of us worked through it all again very carefully and slowly and got the same symptoms. The NIOS doesn't run and I can't connect to it with the debugger.
Repeating the same experiment and expecting a different result is a sign of madness.
0 Compliments
Oliver_I_Sedlacek
4 117 Visites
I'm so demoralised it's taking me some time to summon up the will to beat my head against a brick wall again. Anyway, I've switched to the serial flash controller II and I get different options on the NIOS vectors tab, so I'll give that a go.
0 Compliments
EBERLAZARE_I_Intel
3 896 Visites
I try as in the example design in the Embedded Design handbook, I do see the epcq on the reset vectors in the Nios II IP:
5.2.3.3 Chapter:
0 Compliments
Répondre
