21615 Discussions
BLVDS in Cyclone IV E
i did not find some good note how to implement bi-dir BUS LVDS on Cyclone IV E. My current settings still returns error.
I have one differential signal on fpga which should be used as blvds to half duplex communication between a few cards. There is a note in the manual BLVDS can be used as bidirectional bus to half-duplex communication. The second note which I found says that differential signals have open-drain option disabled. It does not make sense to me. How can I enable open-drain for BLVDS? Because when I use bi-dir blvds quartus returns this error message:
Error (169008): Can't turn on open-drain option for differential I/O pin fe_reset_n_p
When I use ALTIOBUFF and when differential mode is selected then open-drain cannot be used.
Can Cyclone IV E use bi-dir blvds for half-duplex communication?
Thank you for help,
vkle
Hi vkle,
There is a document on this. Does this document help?
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an522.pdf
unfortunately not. When I choose BLVDS and ALTIOBUF then it returns Error (169008): Can't turn on open-drain option for differential I/O pin fe_reset_n_p. This note does help not with this issue.
BR,
vkle
Open drain makes no sense at all for BLVDS. Why do you want to enable it?
Beucase it would be nice to have just one signal for communication. I agree is sounds strange. But there is an sentence in documentation BLVS can handle half duplex communication on one diff signal. This app. note: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an522.pdf
There is described setup tx and rx on one diff signal.
it ends by this error:
Error (176718): Pin fe_blvds0_n uses pseudo-differential output node blvds_driver:i_fe_blvds_reset_n|blvds_driver_iobuf_bidir_l3q:blvds_driver_iobuf_bidir_l3q_component|pseudo_diffa. However, these pins also have an I/O standard LVDS that cannot be supported by the pseudo-differential output node.
vkle
