21588 Discussions
dedicated input clock I/O pin as regular input in Cyclone IV
I would like to use GLK3 dedicated input clock as regular user input on Cyclone IV EP4CE6E22
It seems OK but the fitter (Quartus 13.1) return the following warning:
Warning (176228): Can't pack node xxxx and I/O node xxxx -- I/O node is a dedicated I/O pin
Can I ignore this message safely?
Yes, you can use dedicated clock input pins for general purpose input (but not output) signals. Indeed you can also use general purpose I/O for clock inputs too but if you can avoid it I would.
I don't think that warning is (necessarily) related to such an assignment. I've just tried this and don't see a similar warning.
Do you have a clock going into a general purpose I/O pin? I think that is more likely to result in such a warning. Quartus may find it difficult to route a clock, coming in on an I/O pin, to a large number of registers.
Cheers,
Alex
The warning message concerns an IO input that is not used as a clock. When I have this message (regular input on GCLK pin) the fitter report indicates a fanout of 0.
I have tried to remove the pin allocation and the message disappears. Moreover, in this case the fitter report indicates a fanout of 2...
I don't use clock going into general purpose. All input clocks are located on GCLKx pins.
