21615 Discussions
BLVDS termination for MAX 10
I am using a MAX 10 to drive another chip using LVDS. I am using the true LVDS driver. I would like tobe able to Tri-State the LVDS driver when the power to the chip that I am driving is not enabled. If I use BLVDS, will I need to use any external resistors?
Refer to AN-522 - "Implementing Bus LVDS Interface in Supported Altera Device Families".
Yes - this suggests the use of series termination resistors as well as termination resistors for each end of the bus.
For MAX 10 use the "GPIO Lite IP" core.
Cheers,
Alex
Sorry - I meant to give you the link...
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an522.pdf
Cheers,
Alex
In a first step I would check if the LVDS receiver has any problems with LVDS input being driven while the device is unpowered.
Any LVDS receiver or complex chip with LVDS inputs that I know won't. You might be solving a non-existing problem.
