I've tried to generate BSP using NIOS II 11.1 SBT for Eclipse (right click project ->NIOS II -> Generate BSP), but got the following error.
==================================================== Error executing 'nios2-bsp-generate-files --bsp-dir . --settings settings.bsp', unexpected return code 1. Error message: SEVERE: Available BSP type values for the --type argument are: [hal, ucosii] SEVERE: Available BSP type values for the --type argument are: [hal, ucosii] SEVERE: nios2-bsp-generate-files failed. ===================================================== Anyone who encountered this issue before? What's the cause of this error? How to fix it? Thanks and Regards, DenLink Copied
Have you specified --type to nios2-bsp-create-settings? Here is what documentation (http://www.altera.com/literature/hb/nios2/n2sw_nii52016.pdf) for nios2-bsp-create-settings tool says:
--- Quote Start --- --type <OS name>: BSP type. Use ? or types to list available BSP types for this option. Use names to list the display names of available BSP types. For a Nios II DPX system, always set this argument to lwhal. --- Quote End --- Types available in your setup seem to be either hal or ucosii. The first one stands for Altera's Hardware Abstraction Layer. The former is µc/os-ii (http://en.wikipedia.org/wiki/microc/os-ii).- Mark as New
Hi Yocto,
Thanks for the reply. The thing is the operating system I'm using is FreeRTOS. The bsp type is "freertos". Another issue I found is that when I tried to right-click the project, then go to "NIOS II" -> "BSP Editor". The following error message is displayed in the Problems tab of BSP Editor. ==================== SEVERE: Available BSP type values for the --type argument are: [hal, ucosii] SEVERE: BSP type "freertos" unknown. SEVERE: NullPointerException ============================= I think I encountered this problem when I replaced my software libraries ("Copy and Replace" the project folder) with the latest one. I already cleaned all the projects and rebuild, but I still encountered the problems indicated above. Note that no problems have been encountered whenever I build the project. It's just that I can't re-generate the BSP after compiling to a new system.- Mark as New
The error speaks for itself:
--- Quote Start --- BSP type "freertos" unknown --- Quote End --- You have to use HAL. I am not sure if FreeRTOS supports HAL, you might need to port it.- Mark as New
Hi All,
I finally managed to Generate the BSP using NIOS II 11.1 SBT for Eclipse. I just needed to copy the ff software packages to NIOS IDE: FreeRTOS, LWIP, HAL, as the software is based on Engineering Sprit'sFreertos-NIOS port. Thanks Yocto for help. Regards, Dennis- Mark as New
--- Quote Start --- Hi All, I finally managed to Generate the BSP using NIOS II 11.1 SBT for Eclipse. I just needed to copy the ff software packages to NIOS IDE: FreeRTOS, LWIP, HAL, as the software is based on Engineering Sprit'sFreertos-NIOS port. Thanks Yocto for help. Regards, Dennis --- Quote End --- Hey dennis, how did you managed to Generate the BSP ? i still don't see free_rtos in the operation system list when creating new BSP... thank Mor
