21615 Discussions
BSP editor in Eclipse IDE 11sp1
hi all,
I've recently upgraded from Quartus II 10.1 to 11sp1, because I need to compile the superloop_sss_rgmii_plus example which is developed for this last version.
I successfully implement and P&R the example with Quartus, but when I switch to nios IDE, I cannot found the BSP menu and the other altera tools which are presents in the previously versions of the program.
I attached a screenshot of nios IDE. The installed version is 11.0sp1 Build 208 with legacy package also (first i didn't install them, but in a second time i installed the package hoping resolving the problem but it didn't happened).
In the "About Eclipse" window->installation details, installed software tab I see NiosII software build tools & system console and niosII software build tools for eclipse, so the software is installed; in fact through the niosII command shell I can compile my projects.
Anyone has the same problem or know the trick to bypass it?
many thanks
Alessandro
Please put a smaller screenshot, because this one is too big.
sorry I didn't check the maximum filesize for *.gif file.
I re-attach the screenshot, but it isn't very important because it shown things that are missing:(
I'll wait for your lighting
Ale
Hi Ale,
I had the same problem when I first upgraded from version 10.1 to 11.0 of the Quartus II tools. I had to re-install the entire package to solve the problem. I'm not sure if there was a check box that I missed the first time, or just something quirky about the install process (very likely with Altera). Someone else had posted with the same problem previously, so it's not just us.
I would try un-installing then re-installing QII 11.0 sp1 and keep a close eye on the check boxes during the process.
Good luck!
hi fheineman,
thanks for the reply! I don't understand if I have to tick the Legacy package check box... because if I understand well, this package is useful only for projects created with very old Quartus; for me that I have created projects with QII10.1 is sufficient the Nios II SBT package (that now is automatically installed when you select to install QII).
Is that true?
thanks again
Ale
PS: I see also the old post... now I reinstall all:)
--- Quote Start ---
--- Quote End ---
I would not check the Legacy package.
thanks fheineman,
I've reinstalled all QII11sp1 and the NiosII menu in Eclipse is now appeared!
I confirm that the legacy package is not necessary.
thanks again
Ale
