21602 Discussions
Basic Function Unit Design (ALU + shifter)
I need to design the function unit attached in quartus. I decided to use Block Diagram/Schematic file then export as vhdl.
Is there anything critical you think I should tweak before i start testing. Everything compiled without errors although I have warnings of;
-No superset bus at connection
-Pin ".. " is missing source
-Primitive "XOR" of instance "inst1" not used
-Warning(13410): Pin "F0" is stuck at GND
Are these warnings fatal when exporting to VHDL code?
thanks
