I have a problem with Standalone mode i.e. Booting From On-Chip Memory. I have created a NIOS II Processor and Reset Vector pointing it to On-Chip Memory which resides from address range (On Chip Memory address base=0x4004000 to End =0x40067ff) Written some C Code i.e. a LED counter works well when dumped through NIOS II EDS (i.e. Run As Hardware). Now my Problem is I want to run it in Standalone mode for that I follow 5 Steps- Open NIOS II EDS Console
- Type "
- Copy that boot_rom.hex file to the project working Directory
- Then In Quartus >Settings>Compilation Process Settings Then Check Use Smart Compilation then give compile
- Then dump in FPGA and keep it in Standalone mode
