21588 Discussions
Byte stream devices is not showing up UP USB BLASTER
Dear all
I have a written a basic hello world code and I build the output I got the .elf output But when I try to download .elf file its giving this error,
using cable "usb-blaster [usb-0]", device 1, instance
resetting and pausing target processor: failed
leaving target processor paused
when I tried with the ide its self for configuration I can't find the device name in Target configuration section its blank. Kindly notify me what will be error and rectification for it.
Thanks in advance,
prasanth
If the FPGA properly configured and is it getting a clock signal? What hardware are you using? Which FPGA configuration?
Hi, I have configured it correctly, because the same USB blaster I am dumping my .sof file to the fpga. I am using Stratix V altera in Bittware board.
