21587 Discussions
CCannot continue because of fatal error (sfixed to floating point)
Hi all;
It is possible if I want to convert from sfixed to floating point? For example: convert 000001000 to 0.483..
I try to write like below, but its working for convert integer..
library ieee;
library ieee_proposed;
use ieee_proposed.fixed_pkg.all;
use IEEE.STD_LOGIC_SIGNED.ALL;
use IEEE.numeric_std.all;
entity try is
port (A: in sfixed(4 downto -4);
clk: in bit;
out_A: out integer range -127 to 127);
end try;
architecture try of try is
begin
process (clk)
begin
if (clk'event and clk='1') then
out_A <= to_integer(signed(A));
end if;
end process;
end try;
There are no problems when I compile in quartus. But, a fatal error occur when I simulate in ModelSim. Need helps..Thanks
