21612 Discussions
CPLD VHDL problem
HI,
I am trying to understand the operation of the following VHDL code.
The cpld EPM2210 is attached to a processor bus (d0-d15 and A0-A15).
When I do a double read 'word aligned' address range 0xXXXXX40 to 0xXXXXXX5A
I get:
0xXXXXXX52 = 2357 2357
0xXXXXXX54 = 5678 5678
0xXXXXXX54 = EB67 EB67
0xXXXXXX58 = 08FC 08FC
0xXXXXXX5A = C438 C438
At address 0xXXXXXX58 I expected 1267 and then F23C but I get 08FC and 08FC
WHY!!!!
Any help will be appreciated.
library IEEE;
use IEEE.std_logic_1164.all;
use ieee.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity Top is
port (
-- MICROCONTROLLER BUS
clk : in std_logic;
reset_n : in std_logic;
proc_cs2_n : in std_logic;
proc_rw_n : in std_logic;
proc_oe_n : in std_logic;
proc_addr : in std_logic_vector(17 downto 0);
proc_data : inout std_logic_vector(15 downto 0);
end Top;
architecture Structure of Top is
--3631
--4862
--32c5
--35a9
--3072
constant CPLD_Version_word: ROM_Array2 := (
0 => "0011011000110001",-- Suppose ROM has
2 => "0100100001100010", -- prestored value
4 => "0011001011000101", -- like this table
6 => "0011010110101001", -- like this table
8 => "0011000001110010", -- like this table
OTHERS => "1111111111111111" --
-- states for reading fifo 24 bits
type read_fifo_24_bits is (
idle_state,
read_top_16);
signal state_rd_fifo : read_fifo_24_bits;
begin
-- main process
process(reset_n, clk,state_rd_fifo,
proc_data(15 downto 0),
proc_addr(15 downto 0),
proc_cs2_n,
proc_rw_n,
-- variable must be here
variable state_fifo: integer range 0 to 4:= 0;
begin
-- main reset
if reset_n='0' then
proc_data <= "ZZZZZZZZZZZZZZZZ";
pwm_data0 <= "0000000000000000";
port_out11 <= "00000011"; -- for serial port comms
state_fifo := 0;
-- start decode chip select and decode address input with a READ
elsif (proc_cs2_n='0' and proc_rw_n='1' ) then
case proc_addr(15 downto 0) is
when "0000001100100000" =>proc_data(15 downto 0) <=
CPLD_Version_word(conv_integer(proc_addr(3 downto 0)));
when "0000001100100010"=>proc_data(15 downto 0) <=
when "0000001100100100"=>proc_data(15 downto 0) <=
when "0000001100100110"=>proc_data(15 downto 0) <=
when "0000001100101000"=>proc_data(15 downto 0) <=
when "0000000001010010" => proc_data (15 downto 0) <= X"2357";
when "0000000001010011" => proc_data (15 downto 0) <= X"5678";
when "0000000001010100" => proc_data (15 downto 0) <= X"eb67";
when "0000000001010101" => proc_data (15 downto 0) <= X"e8fd";
when "0000000001010110" => proc_data (15 downto 0) <= X"1ba5";
when "0000000001011000" =>
if(state_fifo = 0) then
proc_data (15 downto 0) <= X"1267";
state_fifo := 1;
else
proc_data (15 downto 0) <= X"abcd";
state_fifo := 1;
end if;
if(state_fifo = 1) then
proc_data (15 downto 0) <= X"f23c";
state_fifo := 2;
else
proc_data (15 downto 0) <= X"2784";
state_fifo := 2;
end if;
if(state_fifo = 2) then
proc_data (15 downto 0) <= X"982b";
state_fifo := 0;
else
proc_data (15 downto 0) <= X"08fc";
state_fifo := 0;
end if;
when "0000000001011010" =>
proc_data (15 downto 0) <= X"c438";
when others =>
proc_data (15 downto 0) <= "ZZZZZZZZZZZZZZZZ";
end case;
end if;
end process;
--- Quote Start ---
WHY!!!!
--- Quote End ---
Look sharp. According to your code, either X"982b" or X"08fc" are send. Only the code starting with if(state_fifo = 2) then is active.
I also noticed, that the CPLD will possibly drive the bus, although not addressed. The output is only correctly tri-stated, if an "others" address is omitted before cs or rd are deasserted. Otherwise the last output word is hold permanently.
Thanks FvM,
Your right I need to open my eyes and wakeup!!
I changed the code so that at the same address (0xxxxxx42) I could read in 24 alternative words. i.e. in this case 24 off (0x1234 and 0x789a).
Can anyone think of why this code does not do this simple task.
when "0000000001000010" => -- read 24 double words
case state_rd_fifo is
when idle_state =>
fifo_enable_read <= '1';
proc_data (15 downto 0) <= X"1234";
fifo_enable_write <= '0';
state_rd_fifo <= read_top_16;
when read_top_16 =>
end_fifo_24_words:= end_fifo_24_words+1;
state_rd_fifo <= idle_state;
proc_data (15 downto 0) <= "789a;
fifo_enable_read <= '0';
if end_fifo_24_words >= 24 then
end_fifo_24_words:= 0;
end if;
when others =>
"ZZZZZZZZZZZZZZZZ";
end case;
when others => proc_data (15 downto 0) <=
"ZZZZZZZZZZZZZZZZ";
end case;
I would primarly ask what kind of process and trigger condition is including the FIFO counter and assignments of state_rd_fifo. A counter or a state variable register can only work under a clock edge sensitive condition, e.g if rising_edge(clk).
Here is the code I am trying to to get to work:
I am interested in the read condition when state_rd_fifo changes state:
process(reset_n,clk,state_rd_fifo,
proc_cs2_n,
proc_rw_n,
state_rd_fifo)
variable end_fifo_24_words : integer range 0 to 30 := 0;
begin
-- main reset
if reset_n='0' then
state_rd_24bits <= idle_state;
read_uart_24 <= '0';
end_fifo_24_words := 0;
state_rd_fifo <= state1;
-- start decode chip select and decode address input with a WRITE
elsif rising_edge(clk) then
if (proc_cs2_n='0' and proc_rw_n='0') then
when "0000000000001110" =>
case state_wr_24bits is
when write_byte_1 =>
temp_word_24_0(23 downto 8) <= proc_data (15 downto 0);
state_wr_24bits <= write_byte_2;
when write_byte_2=>
temp_word_24_1(23 downto 8) <= proc_data (15 downto 0);
if(tx_ready_0 ='1') then -- now write the 24 bits to uart
start_tx_0 <= '1';
tx_data_register_24bit_0 <= temp_word_24_1(23 downto 8) &
temp_word_24_1(7 downto 0);
tx_write0 <='1' ;
state_wr_24bits <= write_byte_1;
end if;
end case;
when state1 =>
proc_data (15 downto 0) <= X"1267"; --temp_word_24_0(23 downto 8);
state_rd_fifo <= state2;
when state2 =>
proc_data (15 downto 0) <= X"f23c"; --temp_word_24_0(23 downto 8);
when others =>
end case;
when "0000000001011010" => proc_data (15 downto 0) <= X"c438";
when others => proc_data (15 downto 0) <= "ZZZZZZZZZZZZZZZZ";
end case;
end if;
end process;
It's not clear to me, what the code is expected to do. As coded, the state machine advances on every clock cycle while read is active. The result depends on the relation of clock and processor bus timing.
