Can Cyclone V SoC use straight SDRAM, that existed before DDR1, DDR2, etc.? Altera says "Support for double data rate 2 (DDR2), DDR3, and low-power DDR2 (LPDDR2) SDRAM" in HPS Technical Reference Manual, so I suspect not, but want to make sure.
Thanks RonLink Copied
there is a module called hps SD ram sub-controller system... maybe is for the SD ram purpose?
