21615 Discussions
Can I exchange the positive signal (p) and negative (n) signal of LVDS?
Can I exchange the positive signal (p) and negative (n) signal of LVDS in Cyclone devices? In order to avoid the use of vias.
Yes.
Of course, you need to negate the signal inside your design.
Important notice: you can't put the inversion between a DDRIO (or ALTLVDS primitive, which uses DDRIO) and the pin.
So, if you're planing to use DDRIO or ALTLVDS, beware of that inversion.
Thanks for your help.
Is the LVDS clock signal can also be inverted inside the FPGA?
--- Quote Start ---
--- Quote End ---
You have to apply a phase shift. In my opinion, inverting the signals is good to fix layout errors, but I won't use it as regular design means.
Extremely grateful.
