21611 Discussions
Can I use a MAX V CPLD as a drop in replacement (code project, pins, etc) for my old MAX II 7256AETC100-7N circuit?
AGipe
I have an old design I am trying to update. From the specs, it looks like a MAX V device (specifically interested in the 5M240ZT1005N) is comparable/better than my current MAX II 7256AETC100-7N. Is my verilog code and pin out compatible with this proposed device as a drop in replacement?
YuanLi_S_Intel
Hi Austin,
Apologize that you cant do that as the pin placement (I/O, GND and Power pin) is not the same.
Thank You.
