I want to use the same programming file in 10CL016YU256 and 10CL016YU484. Can this be done, provided that I use only pins/pads bonded in both device packages?
Hi REics,
Technically you cannot use the same programming file across different packages as the pin's locations are different on each package.
You may perform the migration across the devices within the same package type as you can see in the table below:
Perhaps you may need to update the pin assignment in your design on a different package type.
Fakhrul
As we do not receive any response from you to the previous answer that we provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
