Programmable Devices
21615 Discussions
Can't ECO modify PLL's properties of Cyclone V devices?
Hi guys,
I want to make some small modification on PLL of Cyclone V devices. However, it seems i can't do anything thru ECO on it as altera previous generation deivces (for example Cyclone III). Why?
The PLLs on the Cyclone V don't work the same as the earlier parts. Read the PLL chapter of the device handbook. Since you didn't give any details on what you were trying, I can't say why it doesn't work.
--- Quote Start ---
--- Quote End ---
I want to modify the PLL's output's phase after full compilation, so i used to use ECO to modify it. Which makes me implemented it fast whitout full complie my project again.
Hello, have you tried to follow http://electro-logic.blogspot.it/2015/09/fpga-engineering-change-orders.html (hello, have you tried to follow http://electro-logic.blogspot.it/2015/09/fpga-engineering-change-orders.html) ?
I think it is done with Cyclone IV but should works also with Cyclone V. Are you using Cyclone V PLL IP?
Tutorial is in Italian but you can translate it with Google or Bing.
Altera app note 661 "Implementing Fractional PLL Reconfiguration with Altera PLL and Altera PLL Reconfig IP Cores" seems to explain how to do this. Examples 2 and 4 are on phase shift. This is different from Cyclone IV.
--- Quote Start ---
--- Quote End ---
Hi Flz,
I'm using CV PLL. I can't open your link.
Yeah, with Cyclone V you have to use Altera PLL Reconfig IP
--- Quote Start ---
--- Quote End ---
Hi flz
I don't want to use pll reconfig, i just want to modify the PLL manually after full compilation!
As far as I can tell, flz47655 is correct. The only way to changes the phase of a clock after compilation on Cyclone V is to implement PLL reconfiguration with the Altera IP.
--- Quote Start ---
--- Quote End ---
Hi Galfonz,
Is it means altera doesn't open ECO for PLL to users? Does ALTERA plan to open it to users?
No way to make ECO on PLL due to different structure..
This is a Cyclone V hardware issue, not something that could be changed with a Quartus update. As far as I know the reconfiguration scheme is the only way to adjust clock phase. It can't be done dynamically like the Cyclone IV and before. Re-configuring and waiting for it to lock again is the only way I know of.
