21345 Discussions
Can´t connect to our network licence with QuartusII
we using a floating network-licence on a Win2k8Server. The Flexlm works fine with our licence. But we can´t connect QuartusII Software, installed on workstation(WinXP), to our licenceserver.
FYI:
Host:server
Port:27000
Path: C:\FlexLM\licence.dat
Which is the right command to put in the box "Licence File:"?
eg. from altera readme: "@server:27000@C:\FlexLM\licence.dat
Cheers Tim
we have inside this box the complete path where the used Licence.dat is stored on the server. f.e. "Q:\Altera\Licence.dat"
inside the Licence.dat the first 4 lines :
SERVER MyServerName *MyNICID_MAC* 1800
VENDOR alterad C:\FlexLM\alterad.exe
VENDOR mgcld C:\FlexLM\mgcld.exe
USE_SERVER
FlexLM is stored as you can see on Drive C of the Server and executed there.
Have you tried the lmutil lmdiag to check the connection between you pc and the server that holds the licence ?
on your client you'll want to put 27000@server in the license file or LM_LICENSE_FILE variable.
Here are our first four lines:
SERVER server XXXXXXMACXXX 27000
VENDOR alterad \flexlm\alterad.exe
VENDOR mgcld \flexlm\mgcld.exe
USE_SERVER
This sting is in our Licence file box:
But in my opinion the command in the Licence file box isn´t correct.
Do some body know the right command?
Where could i download "lmutil lmdiag" to check the status? I can only find lmutil.exe in a folder, but this programm doesn´t show any status.
Thanks for your response
Tim
--- Quote Start ---
--- Quote End ---
:mad: Warning: Can't contact license server "27000@server" -- this server will be ignored
Does somebody know which ports are used for communication?
--- Quote Start ---
--- Quote End ---
works fine...
Reason: Firewallsettings on Win2k8!
Thanks for help.
Cheers Tim
