21615 Discussions
Can't place pins - 3C120 Dev kit
Hi Guys,
The board is the Alterra's 3C120 Development Kit.
Sympthom:
There is the DDR2 bottom used. As I addedd the 8 LEDs I got the error message at Fitter running:
Error: Cannot place pin ddr2bot_dq[0] to location AG22
Error: Can't place VREF pin AC18 (VREFGROUP_B4_N1) for pin ddr2bot_dq[0] of type bi-directional with SSTL-18 Class I I/O standard at location AG22
Error: Too many output and bidirectional pins per VCCIO and ground pair in
I/O bank 4 when the VREF pin AC18 (VREFGROUP_B4_N1) is used on device EP3C120F780C7 -- no more than 9 output/bidirectional pins within 12 consecutive pads are allowed when the voltage reference pins are driving in, but there are potentially 10 pins driving out
LEDs get 1.8 V while DDR2 gets SSTL -18 Class 1.
I/O Max toggle frq. is applied to LEDs (0 Mhz)
Anyway, the arrangement of outputs is standard, I use it in several designs, and I remember that sometimes I got the same error message and I could fix it somehow... with some setting or assignment setting, but now i simply don't remember what was the solution:-)) I'm getting old or totaly swamped...
So please provide me a solution if you can. Thank you much in advance!
It seems creating output groups can solve this problem.
HI,
Please tell me if you could solve the problem .I am also stuck in there and I have tried all the options but dont know how to solve it?
