21615 Discussions
nios2-terminal and ubuntu natty
I use ubuntu natty. I installed altera 9.0 quartus and nios2eds. And ran commands:
$ sudo killall jtagd $ sudo chmod 755 /sys/kernel/debug/usb/devices $ sudo chmod 755 /sys/kernel/debug/usb $ sudo chmod 755 /sys/kernel/debug $ sudo mount --bind /dev/bus /proc/bus $ sudo ln -s /sys/kernel/debug/usb/devices /proc/bus/usb/devices $ sudo <quartus_directory>/bin/jtagd "jtagconfig" print:
USB-Blaster 020F30DD "nios2-terminal" print:
nios2-terminal: There are no JTAG UARTs available which match the --device and nios2-terminal: --instance options you provided. But my friend successfully opens nios2-terminal from OpenSuse 11.4.
