21611 Discussions
Can't program the S2GX device with sof file
After compile, if auto detect is clicked:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6927
so I added the sof file to the S2GX device, I dont think i should add it to EPM570, right? only pof goes there, right?
https://www.alteraforum.com/forum/attachment.php?attachmentid=6928
but when i try to program the device, the following msg shows:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6929
(It's trying to program the EPM570, but i explictly selected S2GX!!)
if I remove the EPM570 device, this is what i get:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6930
Can anyone help me to solve the problem? Thanks
In the first image, the JTAG chain autodetects the MAX II then the SII.
In the second image, you have somehow managed to accidentally change the order.
Click auto-detect, add the file for the S II without changing the device order, and it should work fine.
Cheers,
Dave
thanks, it works
--- Quote Start ---
thanks, it works
--- Quote End ---
Great! :)
Cheers,
Dave
