I am trying to determine the type of bit file needed to program into a serial flash to use for active serial loading of a Stratix V when cvp init mode is used. Convert programming files does not allow selection of the cvp periph and core files when a .rpd output file is selected. Selecting a .rbf file allows generation of the periph and core rbf files, but rbf files are not compatible with active serial mode configuration.
Generation of a .jic file works, but I need a programming file to be loaded onto the serial flash in a running system without a JTAG cable attached. I have a gpio interface to the serial flash to read/write the flash data for in system programming, now I just need to find how the generate the core design file to load into the flash for cvp init mode.Link Copied
