21615 Discussions
Car Park Indicator System
i need to design a car park indicator system for a space with 8 lots. it needs to have the following specifications:
  1. a seven-segment display to indicate the number of free lots.
  2. presettable up/down counter
  3. each lor has a light which will turn on to indicate that is free
  4. the light should turn off when the lost is occupied
  5. when the lot is filled to the maximun of 8 cars, the seven-segment should display 'F' the indicate it is full
i have to write a VHDL code for this but i aint sure how to, can any one help me with it? i aint sure if what i did is right or wrong
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY carpark IS
PORT(
d0,d1,d2,d3,clock, reset, led : in std_logic;
in_sensor : in std_logic;
out_sensor : in std_logic;
l : out std_logic_vector (7 downto 0);
a,b,c,d,e,f,g : out std_logic);
q: out std_logic_vector(2 downto 0 ));
end carpark;
architecture arc of carpark is
signal input: bit_vector (3 downto 0);
signal output_lights: bit_vector (7 downto 0);
signal output_7segment: bit_vector (6 downto 0);
type state type is (l0,l1,l2,l3,l4,l5,l6);
begin
process (in_sensor, out_sensor)
begin
output_lights <= "1";
elsif falling_edge (out_sensor) then
output_lights <= output_lights -1;
end if;
input (3)<= d3;
input (2)<=d2;
input (1)<=d1;
input (0)<=d0;
begin
input<= d3 & d2 & d1 & d0;
with input select
output<= "0000000" when "0000",
"0001111" when "0001",
"0100000" when "0010",
"0100100" when "0011",
"1001100" when "0100",
"0000110" when "0101",
"0010010" when "0110",
"1001111" when "0111",
"0111000" when "1000",
"1111111" when others;
a <= output(6);
b <= output(5);
c <= output(4);
d <= output(3);
e <= output(2);
f <= output(1);
g <= output(0);
end if;
end process;
end carpark;
lots of syntax errors. I suggest fixing these before we go further.
could you help me with it? i am so confused and i dont know how to do it
Run it through a compiler and it will tell you
It looks like a school assignment, am I right. If it is, you could also ask your teacher.
well there is alot of problems and i dunno how to solve them
--- Quote Start ---
--- Quote End ---
it is but my teacher wont help with this assignment
--- Quote Start ---
--- Quote End ---
Run the code through a compiler - it will tell you where the errors are and what they are. Then you can fix them.
True, it is difficult to tell or spot some minor error. Any compiler give u more precise information on what the problem is. Also it will show u which line is problematic. With this info, if u still not able to fix, u can paste the error here, and people and help u from there
--- Quote Start ---
--- Quote End ---
these are the errors
Error (10500): VHDL syntax error at carpark.vhd(10) near text "q"; expecting "end", or "begin", or a declaration statement
Error (10500): VHDL syntax error at carpark.vhd(10) near text ")"; mismatched closing parenthesis
Error (10523): Ignored construct carpark at carpark.vhd(3) due to previous errors
Error (10500): VHDL syntax error at carpark.vhd(18) near text "type"; expecting ";", or "is"
Error (10500): VHDL syntax error at carpark.vhd(24) near text "elsif"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at carpark.vhd(24) near text "then"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at carpark.vhd(26) near text "if"; expecting "process"
Error (10500): VHDL syntax error at carpark.vhd(34) near text "begin"; expecting "end", or "(", or an identifier ("begin" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at carpark.vhd(36) near text "with"; expecting "end", or "(", or an identifier ("with" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at carpark.vhd(37) near text "when"; expecting ";"
Error (10500): VHDL syntax error at carpark.vhd(55) near text "if"; expecting "process"
Error (10396): VHDL syntax error at carpark.vhd(57): name used in construct must match previously specified name "arc"
Info: Found 0 design units, including 0 entities, in source file carpark.vhd
Error: Quartus II Analysis & Synthesis was unsuccessful. 12 errors, 0 warnings
Error: Peak virtual memory: 222 megabytes
Error: Processing ended: Wed Jul 31 22:10:50 2013
Error: Elapsed time: 00:00:04
Error: Total CPU time (on all processors): 00:00:03
Error: Quartus II Full Compilation was unsuccessful. 14 errors, 0 warnings
You should check the second error first. in this case I think it is also the cause of at least the first error.
ad in the process you start with an elseif, you should start with an if statement. I suggest reading chapters (or search the web) about the if statement.
Also you should take a look at how to open and close entities and architectures.
Finally I give you a tip: Use tabs to line your code. As you start a block (if, begin, port, etc.) you use a tab on the next line, this improves reading and thereby you can easily find problems related to errors like 10500.
Why are you telling us and not fixing them?
--- Quote Start ---
--- Quote End ---
that was because the forum strips out leading whitespace unless you use code tags.
--- Quote Start ---
--- Quote End ---
I know, but still, if you do this right it helps. You'll be surprised how many times I get code from project mates who don't use this.
