Programmable Devices
21605 Discussions
Carry chain on Cyclone V GX using a 1bit adder
benji1312
Hello everyone,
I am new to the world of FPGAs, and I need to do a Time to Digital Converter, thus I would need to use a carry chain to precisely mesure time.
I tried a few different things:
- Using the "CARRY_SUM" primitive : I have no idea if I used it right, I basically took 5 of them and connected the cout of one to the cin of the next. It wasn't recognized as a carry chain at all by Quartus
- Using a 4 bit LPM_ADD_SUB: This actually kind of worked, but I would like to convert it to a 1 bit adder, and have 1 adder = 1 ALM, just for things to be easier.
Right now I have created a 1 bit LPM_ADD_SUB, and added it in a VHDL component as follows :
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY carryChainElement IS
	PORT (
		a,b: IN std_logic;
		cin: IN std_logic;
		cout: OUT std_logic;
		sum: OUT std_logic
END carryChainElement;
ARCHITECTURE RTL OF carryChainElement IS
	COMPONENT addSub
		PORT (
			dataa: IN std_logic_vector(0 downto 0);
			datab: IN std_logic_vector(0 downto 0);
			cin: IN std_logic;
			result: OUT std_logic_vector(0 downto 0)
	END COMPONENT;
BEGIN
	addSub1: addSub
		PORT MAP (
			dataa(0) => a,
			datab(0) => b,
			cin => cin,
			cout => cout,
			result(0) => sum
END RTL;
Then I added this component to my .bdf file like this (I added the input and output pins because if I put a constant value in a and b, then Quartus would have optimized it away, I also did the same in my other attemps with the CARRY_SUM primitive and the 4 bit adder) :
After the compilation, the chip planner gives me this result :
And finally, the RTL viewer looks like this :
As you can see, Quartus does not recognize it as a carry chain.
I have read the documentation on the Cyclone V, and I understand the concept of ALMs, Arithmetic mode, etc... I just don't know how to actually implement it.
Do anyone have any leads on how I could fix my current attemps with the 1bit adder ?
Thanks a lot,
Benjamin
ShengN_Intel
Do you mean using 4 bit LPM_ADD_SUB, there's no problem on implementing the carry chain? Possible screenshot the rtl viewer?
Sheng
benji1312
So here is my RTL view with the 4bit LPM_ADD_SUB,
And here is the chip planner view :
For the RTL view, it looks the same as the 1bit version (with 4 bit instead of 1 obviously), and on the chip planner we can clearly see that the carry chain is used, even though some optimization seems to occur as we only use 3 ALM.
Thank you,
Benjamin
ShengN_Intel
Hi Benjamin,
Possible to provide the design file .qar of both 1-bit and 4-bit LPM_ADD_SUB for more detailed viewing?
Sheng
benji1312
Sure, here are the 2 files.
Thanks for your help,
Benjamin
FvM
example of full adder implemented with lcell_comb wysigwyg primitive can be found in Advanced Synthesis Cookbook, the module is part of basic_adder.v It can be directly used for Cyclone V because Stratix utilizes same 6-input LUT logig cell.
Problem is that cin and cout can't be directly routed to I/O pins, carry chain can only start and end in other logic cells, as gate level logic circuit of full adder shows. When designing with cyclonev_lcell_comb, the interconnect lcells are generated automatically.
Frank
benji1312
Hello Frank,
I just tried it quickly and it seems to be working,
I'm gonna take some time to understand exactly why it is working, and if I have any issues I'll get back to you.
Thanks a lot to you two for your help.
Benjamin
ShengN_Intel
May I know the suggested way helps? Any further concern or consideration?
Sheng
