21615 Discussions
Carry chain on Cyclone V
I'm new and I have a problem with implementation carry chain in Cyclone V. I have to make a ring oscillator on this line and I have a problem with which component should I use ?
I think about component carry_sum or lpm_add_sub.
Also I have a problem with carry_sum. In quartus prime this buffers carry_sum are ignored and nothing. Do you have any suggestion ? :confused::confused:
I would do your best to avoid putting a ring oscillator in an FPGA. They're difficult to do and timing gives them a huge variation over PVT, making them not very reliable. That being said, sometimes there is a good reason and I put together the following design. Hopefully it helps.
http://www.alterawiki.com/wiki/ring_oscillator
