Is it possible to change the DDR2 high performance controller II with AltMemPhy clock frequency without having to do edit the Altmemphy megafunction and then regenerating all the files again?
I thought maybe editing the altmemphy PLL in the megawizard would work but of course the timings will be off if I change just the PLL frequencies. How should I go about it? I needed to change just the clock frequencies without having to regenerate all the files. ThanksLink Copied
