21615 Discussions
Checking lifecycle status of EPM3064ATC100-10N
Manojkumarmurugesan
Please let me know the Parts EPM3064ATC100-10N  is Active/Discontinued. If Active can you please let me know the "year to end of life". Is there any plans to discontinue these parts EPM3064ATC100-10N, If the part is obsolete could you provide an replacement against this part : EPM3064ATC100-10N.
_AK6DN_
Valued Contributor II
Check this thread:  https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Drop-in-Replacement/m-p/1209795
And this thread: https://community.intel.com/t5/Programmable-Devices/Altera-MAX3000-series/td-p/713684
The MAX3000 series went EOL back in 2018.
No direct replacements from Intel/Altera.
You might check on the Microchip ATF1500 series parts there may be a size/package combo you can use.
If I read the datasheet correctly, the ATF1504ASV-15AU100 should be a drop in replacement for the EPM3064ATC100-10.
The only difference is in the speed grade rating of 15ns vs 10ns. So depending on your application requirement, YMMV.
You can use their POF2JED program to convert your Intel/Altera .pof file to a .jed file to program the Microchip/Atmel.
_AK6DN_
NazrulNaim_Intel
As user 'AK6DN' have replied to this question. The answer can be accepted as the solution for this case.
Nazrul Naim
Manojkumarmurugesan
Nazrul Naim, Yes we are on working with that and thanks for the support , Hence we are closing the issue.
