Programmable Devices
공지
21615 토론
Classic DMA core speed?
명예로운 기여자 II
1,424 조회수
Hi everybody,
Please allow me one silly question. Let me explain small problem. I have one DMA inside Qsys, 1x 16bit PIO, SDRAM controller (16bit databus width). All peripherials are running at 100MHz. When I will force to transfer 100 dma transacations it takes 200 clock cycles. Is it correct? I was thinking when I am feeding DMA with 100MHz it will make 100 DMA transactions in 100 clock cycles.
Now the solution could be made by incresing the FCLK to 200MHz but I my SDRAM chips are 133MHz... I am little confused about the speeds and abilities of this configuration.
Could someone please make me short explanation?
Thank you,
Jan.
0 포인트
4 응답
명예로운 기여자 II
735 조회수
Hi Jan:
The DMA core basically just allows you to initiate a transaction of a specific size to a specific location with minimal CPU overhead. The latency required for the transaction is dependent upon many factors, include arbitration cycles, ram paging etc. A 2 to 1 ratio sounds very reasonable.
This is much faster than A CPU would be able to copy the bytes to the memory via instructions. If you truly need a 1 to 1 for a limited number of cycles, put it into a fifo or TCM (Tightly Coupled Memory).
Pete
0 포인트
명예로운 기여자 II
735 조회수
--- Quote Start ---
Hi Jan:
Pete
--- Quote End ---
Thanks for the answer... When I was studying about TCM I have read that it is possibile to use only with the internal onchip slave... so I think that my external SDRAM is not capable of TCM.. Am I right?
So only what I can do is to increase the Fclk to the top of the SDRAM possibilities to drag even more speed from DMA?
Thanks for advice
0 포인트
명예로운 기여자 II
735 조회수
Hi Jan:
TCM is on-chip memory, so the size will be limited.
Is your SDRAM just 16 bit wide as well, or is it wider?
If you are going to say a 64 bit interface, 16 bits at a time, it's going to be more efficient to pack it into 64 bit words then use the DMA to transfer the 64 bits at a time.
It's something to look into at least.
One thing to consider when using an different clock for the SDRAM than for the rest of your logic, this will have a latency penalty as well, since this would require clock crossing logic to prevent meta-stability.
Pete
0 포인트
명예로운 기여자 II
735 조회수
Thank you for the reply... Now it is clear.. I suppose that with my HW configuration I will use just the 2:1 ratio..
Have a nice day.
0 포인트
응답
