21613 Discussions
Clock and frame sync on LVDS link, Cyclone 5
Hi all,
I am to design a connection between two cyclone 5 gx on our upcoming boards. There shall be 4-16 bidirectional links with speed 300-800mb each,
running on kind of backplane + boards assembly.
I would like to avoid using transceivers due to its limited count and higher cost of FPGAs.
Also, I would like to keep just minimal count of wires for each link (1 pair for Rx, one for Tx, no clocks, no frame sync) if possible.
So I am considering to implement simple "transceiver like" approach using lvds but with slower frequencies.
My raw idea:
- Rx side with ALTLVDS_RX plus external PLL + 8/10 decoder in LEs
- "some" logic to sync frames.. I could transmit special pattern or to use "start-stop" or other technique ?
- Tx side with ALTLVDS_TX + 8/10 encoding and "some" training state logic
- Mutual feedback about "locked" state
Since I am to design both side of communication, I am free to implement whatever approach is feasible.
On the other hand I am quite a newbie, so this will be a big challenge in all cases :cool:
I would appreciate any opinions from you - experienced guys.
Could you say if it is viable solution or to suggest other approach ?
Also any related resources/examples are welcome.
Alex
