21604 Discussions
Command line powershell programming a stratix with .sof files
Pia
Hi
I am trying to program an stratix on a DIGILAB SX 10 UHD platform through windows powershell but it is not working for me. I get two types of messages but unfortunately in neither case the FPGA is programmed. Can anyone help me?
I get this reply if I call below with a -v at the end
Version 23.2.0 Build 94 06/14/2023 SC Pro Edition
Copyright (C) 2023 Intel Corporation. All rights reserved. There are actually two units in the chain.
But if I can one programmed then I would also be able to get the second one programmed.
or  if make the call without -v
Error (213013): Programming hardware cable not detected
C:\intelFPGA_pro\23.2\qprogrammer\quartus\bin64\quartus_pgm.exe --cable=usbblasterII --mode=JTAG --"operation=P;C:\fpga_top_U1.sof"
C:\intelFPGA_pro\23.2\qprogrammer\quartus\bin64\quartus_pgm.exe --cable=usbblaster --mode=JTAG --"operation=P;C:\fpga_top_U1.sof"
C:\intelFPGA_pro\23.2\qprogrammer\quartus\bin64\quartus_pgm.exe --cable ="DIGILAB SX 10 UHD [USB-1]" --mode=JTAG --"operation=P;C:\fpga_top_U1.sof"
WZ2
Hi there,
You can change the parameter "--cable xxx" to "-c 1" and try again~
WZ2
Hi there,
Is it worked?
