21612 Discussions
Compilation error in pipemult project.
MRavi1
Untitled.pngError (275021): Illegal wire or bus name " " of type signal
Error (12153): Can't elaborate top-level user hierarchy
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 2 errors, 2 warnings
Can anyone please help me understand what exactly I should do to rectify it?
Vicky1
Check the connections of clock,wren(need to be wire) of ram instance & PRN, CLRN should connect inputs using pin tool.
please let me know if you have any different concern.
Vicky
MRavi1
sstrell
Just to explain a bit clearer, you have clock and wren connected as busses (thick lines) instead of individual wires (thin lines). Delete the busses and use the wire tool to make the connections. Also, the reset input into the register (CLRN) should be hooked up as well, either to an I/O pin or perhaps even just pulled high.
#iwork4intel
MRavi1
Yes. I tried that too, I just had some problems with installation. Once I re-installed the software it worked fine. Thanks !
NSola3
Can you share the source codes files for this or link for the same?
