21611 Discussions
Configuration Problem
Please help me revole the problem. Thanks.
I use EP3C120 and EPCS64 in my design. After I download the POF file to the FPGA and disconnect USB Blaster, the FPGA can't be configurated. But when I connect the USB Blaster to the board and do no operation in software, it can be configurated with EPCS64 correctly.
I was so confused.
You checked if the SOF file is time limited?
And Check JTAG connections : pull-up...
