21602 Discussions
Connection of pll_ref_clk in an Arria10 with one JESD204b receiver
noria
I am using an Arria10 and I implement one JESD204b receiver to communicate with one ADC which has the following paramters LMF=422.
According to the user guide I should connect to the pll_ref_clk, the output of of an ATX_PLL. However when doing this, the tools complains that this is not feasible and require connection of the reference clock (from the pin) straight. Thus two questions:
  • Is this correct?
  • If yes, then what the ATX_PLL is for (since I have only one receiver over four lanes and no bonding clock connection is offer at the IP ports)
Nicolas
noria
HI
Well the page 66 of the JESD204B IP specify that the transceiver PLL need to be out of the transceiver for Arria10 device (the one I am using).
Rahul_S_Intel1
Hi ,
May I know where you find in the document ATX_PLL output to pll_ref_clk. The reference clock has to be connected from the dedicated clk input pins
noria
HI
Rahul_S_Intel1
Hi ,
Can you please check the upstream PLL ( that is the pll driving the ATX pll) you have the option provided as cascade.
JESD user guide
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-design-ex-jesd204b.pdf
