21615 Discussions
Constraint the path between CPU and FPGA
hi, all
I want to constrain the path between CPU and FPGA. Timing diagram bellow is cutting from the datasheet of CPU
current contraints:
1. address latch enable input port, set_input delay for both rise and fall edge
set_input_delay -rise -max -clock [get_clocks {CLK}] t11max [get_ports {ALE}]
set_input_delay -rise -min -clock [get_clocks {CLK}] t11min [get_ports {ALE}]
set_input_delay -add_delay -fall -max -clock [get_clocks {CLK}] t21max [get_ports {ALE}]
set_input_delay -add_delay -fall -min -clock [get_clocks {CLK}] t21min [get_ports {ALE}]
2. ship select input port
set_input_delay -rise -max -clock [get_clocks {CLK}] t24max [get_ports {CPU_CS1 CPU_CS2}]
set_input_delay -rise -min -clock [get_clocks {CLK}] t24min [get_ports {CPU_CS1 CPU_CS2}]
set_input_delay -add_delay -fall -max -clock [get_clocks {CLK}] t14max [get_ports {CPU_CS1 CPU_CS2}]
set_input_delay -add_delay -fall -min -clock [get_clocks {CLK}] t14min [get_ports {CPU_CS1 CPU_CS2}]
3. read and write input port
set_input_delay -rise -max -clock [get_clocks {CLK}] t20x [get_ports {CPU_WRH CPU_WRL}]
set_input_delay -rise -min -clock [get_clocks {CLK}] t20n [get_ports {CPU_WRH CPU_WRL}]
set_input_delay -add_delay -fall -max -clock [get_clocks {CLK}] t10max [get_ports {CPU_WRH CPU_WRL}]
set_input_delay -add_delay -fall -min -clock [get_clocks {CLK}] t10min [get_ports {CPU_WRH CPU_WRL}]
4. FPGA-TO-CPU data output port
set_output_delay -clock {get_clocks {CLK}} -max t30 [get_ports {CPU_D}] -add_delay
set_output_delay -clock {get_clocks {CLK}} -min t31 [get_ports {CPU_D}] -add_delay
Are the constraints above correct? And I'm little confused how to contrain CPU-TO_FPGA input port?
Thx
