21611 Discussions
Contraining source synchronous interfaces
Hello all!
I'm trying to understand how to constrain source synchronous interfaces and I'm having some difficulties.
Could someone please explain the following:
When we have two flip flops inside the FPGA, the setup time on that path is equal to the clock period, i.e. the first flip flop launches data at 0ns, and the other should latch it at 10ns for a 100 MHz clock.
In case of a single data rate source synchronous interface, when FPGA is the receiver and the transmitter is sending edge-aligned data, why is the launch edge equal to the latch edge? Why can't the transmitting flip flop send the data at 0ns, and FPGA capture it at 10 ns as in the case of an internal FPGA path?
Why do those two paths (path inside FPGA, path from tx to fpga input) have different default setup/hold relationships? Please see the below image for the default setup/hold relationship of the edge aligned source synchronous interface which I'm having difficulty understanding.
https://alteraforum.com/forum/attachment.php?attachmentid=14580&stc=1
Thank you!
--- Quote Start ---
Hello all!
--- Quote End ---
No the setup relationship(not tSU) is 10ns, hold relationship is 0ns. The launch and latch must occur within the 10 ns window minus tSU+tH
--- Quote Start ---
--- Quote End ---
Launch is always first then data is latched on next clock. Who says otherwise?
--- Quote Start ---
--- Quote End ---
Ok, but why is then setup relationship=0ns at the FPGA input?
--- Quote Start ---
--- Quote End ---
At the FPGA io you can play some games to achieve timing.
option 1: usual default behavior i.e. latch on next edge
option 2: same edge launch/latch; if that helps timing
No 2 is possible because as long as data stream is sampled correctly it doesn't matter if delay or advance is introduced. In this case the fitter will see if it is achievable or not.
Inside fpga's rtl chain the default is strict that latch is on next edge. At io you the user have other choices. Remember the clk edge is arbitrary and what matters is sampling correctly rather specifically on a given clock edge.
--- Quote Start ---
--- Quote End ---
Just wanted to bring to your attention that Altera's documentation says otherwise. Screenshot from AN433, page 4:
https://alteraforum.com/forum/attachment.php?attachmentid=14590&stc=1
Ok, thank you for you reply.
I saw in the Altera's source synchronous interface online training the default setup relationship at 0 ns (screenshot in my original post, blue arrow is setup), so I was wandering why this was the case.
It says "may be"
"By default, timing analysis operates on the assumption that data launched by the
rising clock edge is latched by the next rising clock edge. Source-synchronous
interfaces, however, often exhibit different behavior. Data may be latched by the same
edge that launches it, and source-synchronous DDR interfaces launch and latch data
on rising and falling clock edges"
The receiver in an edge-aligned, source synchronous interface is responsible for phase shifting (180 degrees for SDR, 90 degrees for DDR) the incoming clock to center align it with the incoming data. TimeQuest for I/O interfaces works from the edge (the I/O) of the device. As such, in the edge-aligned case, the launch and latch edges are basically on top of each other. The FPGA with a PLL will shift the latch edge later to align it with the data.
So in the diagram you posted, picture the destination clock shifted 180 degrees to the right, keeping the red and blue arrows pointing to the same edges.
