21611 Discussions
Converting from AHDL to Verilog
After 15 years of writting AHDL programs, I am switching to Verilog. In
my AHDL programs I normally have the "top" or "main" program contain
the include statements , then I/O pin assignments, and finally I/O
port assignments for the many lower modules. There is usually no logic in the top
level file. I have read many books and tutorials but have not found a good
example on how to create this structure in Verilog. Is this the right approach for
doing hierarchical design in Verilog. Any tips or examples would be appreciated.
Thanks!!!!!
I did verilog ages ago, I used the following template, I hope it will help but may need considerable updating:
// A sample Verilog program structure ‘include “file1.v” // lower module macro ‘define “my_line” 16’hBB7F // line macro //design IF module my_design (a,b,c,d) input a,b; //direction,width,name input c; output d; //internal design declarations // reg d; //output registered wire w1,w2 //for instantiation or node wiring integer I; //general use e.g. loop index parameter k = 4’b1 //literal ‘include “file2.v” //macro replacement function f1; input a; parameter k = 8’10001110”; integer n; begin Sequential statements... end endfunction task t1; input a; output b; parameter k = ‘8b11110000”; begin Sequential statements... end endtask //start of design //instantiations Lower_mod1# (5,8) mod_1(w1,w2); //positional association Lower_mod2 mod2 ( .a (w1), .b () ); //named association //wiring assign w3 = ~(a & b); //continuous assignment //intial values initial begin ... end //seq like process of vhdl always @ (a or b) begin ... end endmodule
Thanks a lot! A quick question, if "module my_design (a,b,c,d)" is the top level why does it have parameter after it? thanks again!:confused:
Parameter is optional literal for readability to be used locally inside the design instead of directly embedding numbers (dec/binary or octal or hex) for example.
