cycloneII
I tried to compile several times the standard that exists in DE2 CycloneII_2c35 quartus always there will be errors
Do you know why?
Is there a version without error
Cordially
actually, I don't have DE2.
what kind of error do you see?
did you compile SOPC builder, before you compile QuartusII project.
we need more information to help you.
hello
yes I compile the spoc builder and I have the error
you can try to installe the quartus then go to this path:
C:\altera\61\nios2eds\examples\vhdl\niosII_cycloneII_2c35\standard
open standard quatrusII project file and do compile
and you have the error
everything is my guess.
since you didn't write which error was occurs.
do you use QuartusII6.1?
if you use different version of QuartusII.
you may need to rebuild (not recompile) SOPC builder.
anyway you should write error message here.
someone may help you then.
hello
the error in quatus is in fallowing
Error (10481): VHDL Use Clause error at ddr_sdram_auk_ddr_sdram.vhd(27): design library "work" does not contain primary unit "auk_ddr_functions"
Error: Node instance "ddr_sdram_auk_ddr_sdram_inst" instantiates undefined entity "ddr_sdram_auk_ddr_sdram"
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 16 warnings
Info: Allocated 173 megabytes of memory during processing
Error: Processing ended: Mon May 02 12:50:29 2011
Error: Elapsed time: 00:00:15
Error: Quartus II Full Compilation was unsuccessful. 2 errors, 16 warnings
