21616 Discussions
Could you help provide the IC MTBF/FIT for "10M16DCF484C8G"?
JChen247
TF-IC;PLD/GAL/CPLD,SBU,Oregon,J46501-001,10M16DCF484C8G,FPGA,0 ns,3.3V,FBGA,484Pin,MAX 10
ChiaLing_T_Intel
To know the MTBF or Failure-in-time rate (FIT), you may refer to the following solution:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd04072012_59.html
You can find the FIT rate for Altera devices in the Reliability Report. Kindly be noted that the FIT rate for devices within the same family with the same process technology will be very similar and can be used for devices not explicitly listed in the Reliability Report.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rr/rr.pdf
Thank you
Chia Ling
