Counter Problems
im trying to implement a counter which counts positive, negative, or both edges of an incoming signal. It works, but if I give 10000pulses to it it counts only between 9980...9997. The internal FPGA clk is 10MHz and the signal to count comes along with 1kHz and a ontime of 50usec.
Here is the counter part:
Detect_Edges : FOR i IN 1 TO nbr_of_Counters GENERATE
PROCESS(Clk_I, reset_I, Enable_S, CntEdge_S, DIO_Stati_I, CountPort_S)
VARIABLE was_on : boolean;
VARIABLE cnt : integer;
BEGIN
IF reset_I = '1' THEN
cnt := 0;
was_on := TRUE;
ELSIF rising_edge(clk_I) THEN
IF ResetCounter_S(i) = '1' THEN
cnt := 0;
was_on := TRUE;
ELSIF Set_Counter_S(i) = '1' THEN
cnt := CONV_INTEGER(unsigned(CntSet_value_S));
ELSIF Enable_S(i) = '0' THEN
NULL;
ELSIF DIO_Stati_I(CountPort_S(i)) = '1' AND was_on = FALSE THEN
was_on := TRUE;
IF CntEdge_S(i) /= COUNT_ON_FALLING_EDGE THEN
IF CntDir_S(i) = '1' THEN
cnt := cnt + 1;
ELSE
cnt := cnt - 1;
END IF;
END IF;
ELSIF DIO_Stati_I(CountPort_S(i)) = '0' AND was_on = TRUE THEN
was_on := FALSE;
IF CntEdge_S(i) /= COUNT_ON_RISING_EDGE THEN
cnt := cnt + 1;
ELSE
cnt := cnt - 1;
END IF;
END IF;
END IF;
CntValues_S(i) <= CONV_STD_LOGIC_VECTOR(cnt,32);
END IF;
END PROCESS;
END GENERATE;
Has anyone an idea?
If i count the pulses with an other counter the# is correct
Your code is too nested and complicated...
the following idea of counting may help
signal count : signed(32 downto 0); signal temp : signed(1 downto 0); process(reset,clk) begin if reset = '1' then in_signal_d <= '0'; temp <= "00"; count <= (others => '0'); elsif rising_edge(clk) then in_signal_d <= in_signal; -- your incoming signal if count_up = '1' then temp <= "01"; -- +1 else temp <= "11"; -- -1 end if; if in_signal /= in_signal_d then -- either edge count <= count + temp; end if; end if; end process; cnt <= std_logic_vector(count);
I'd add to Kaz's reply by saying that I'd pass in_signal through two registers and not present the "raw" unsynchronised signal to any logic, in order to avoid metastability:
in_signal_d <= in_signal; in_signal_dd <= in_signal_d;
and then:
if in_signal_d /= in_signal_dd then ...
(I'd also probably separate the code out into two processes but that's just my personal preference).
Yes indeed, but I have assumed the signal is synchronised already
thanks for your fast response!
The Signal which i want to count is asynchrounous!
I'll test the process you wrote.
Patrick
Now it works. The problem was the unsynchronised signal. When i register it, as batfink wrote there ar no more problems!
Thanks again
