21618 Discussions
bootloading doesn't starts
I've have a system in CycloneIII EP3C40 with, NIOS + CFI_Flash + ....
I want to write in flash .sof & .elf files to boot entire system from flash memory.
My application is running fine if I program .sof from quartus and application under NIOS IDE -> Run as hardware.
I've been trying to use Flash programmer from NIOS IDE.
# !/bin/sh # # This file was automatically generated by the Nios II IDE Flash Programmer. # # It will be overwritten when the flash programmer options change. # cd E:/GIF/Projects/CycloneIII_3c40_DSP_Setelsa/software/CycloneIII_3c40_DSP_Sete lsa/Debug # Creating .flash file for the FPGA configuration "$SOPC_KIT_NIOS2/bin/sof2flash" --offset=0x0 --input="E:/GIF/Projects/CycloneIII _3c40_DSP_Setelsa/CycloneIII_3c40_DSP_Setelsa.sof" --output="CycloneIII_3c40_DSP _Setelsa.flash" Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert E:/GIF/Projects/CycloneIII_3c40 _DSP_Setelsa/CycloneIII_3c40_DSP_Setelsa.sof CycloneIII_3c40_DSP_Setelsa.rbf Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 54 megabytes Info: Processing ended: Tue May 12 12:05:38 2009 Info: Elapsed time: 00:00:00 Info: Total CPU time (on all processors): 00:00:00 # Programming flash with the FPGA configuration "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00000000 --sidp=0x12003d18 --id=1003684756 --timestamp=1241541969 --instance=0 "CycloneIII_3c40_DSP_Setels a.flash" Using cable "USB-Blaster ", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x12003D18: verified : Checksumming existing contents 00060000 : Verifying existing contents 00080000 : Verifying existing contents 000A0000 : Verifying existing contents 000C0000 : Verifying existing contents 000E0000 : Verifying existing contents 00100000 : Verifying existing contents 00120000 : Verifying existing contents 00000000 : Reading existing contents 00020000 : Reading existing contents 00040000 : Reading existing contents Checksummed/read 780kB in 19.3s 00000000 ( 0%): Erasing 00020000 (33%): Erasing 00040000 (66%): Erasing Erased 384kB in 1.2s (320.0kB/s) 00000000 ( 0%): Programming 00020000 (10%): Programming 00040000 (21%): Programming 00060000 (32%): Programming 00080000 (32%): Programming 000A0000 (32%): Programming 000C0000 (32%): Programming 000E0000 (32%): Programming 00100000 (32%): Programming 00120000 (32%): Programming Programmed 1164KB in 4.9s (237.5KB/s) Device contents checksummed OK Leaving target processor paused # Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00000000 --end=0x7ffffff --reset=0x0 -- input="CycloneIII_3c40_DSP_Setelsa.elf" --output="EXT_FLASH.flash" --boot="C:/al tera/80/ip/nios2_ip/altera_nios2/boot_loader_cfi.srec" # Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00000000 --sidp=0x12003d18 --id=1003684756 --timestamp=1241541969 --instance=0 "EXT_FLASH.flash" Using cable "USB-Blaster ", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x12003D18: verified : Checksumming existing contents 00000000 : Reading existing contents 00020000 : Reading existing contents 00040000 : Reading existing contents Checksummed/read 89kB in 2.2s 00000000 ( 0%): Erasing 00020000 (33%): Erasing 00040000 (66%): Erasing Erased 384kB in 1.0s (384.0kB/s) 00000000 ( 0%): Programming 00020000 (33%): Programming 00040000 (66%): Programming Programmed 296KB +88KB in 5.0s (76.8KB/s) Device contents checksummed OK Leaving target processor paused
After completion, i remove USB blaster and power, and I applied power again but FPGA doesn't starts.
Any suggestion???
What version of tools are you using? There is a problem with the 9.0 version of the flash programmer, at least when using C3 and an EPCS.
I'm using Quartus II 8.0sp1, I tried to write .sof and ,elf in flash, but now I've programmed .sof within epcs memory and it works.
Hi rbarnes,
what kinds of problems there are with the flash programmer?? I use the programmer with several boards and I updated the Quartus 2 version few days ago! The service pack 1 solve this issues??
It seems that with Quartus 9, the programmer doesn't put the software correctly in the EPCS device when used with a Cyclone III, preventing the Nios to boot.
This is not corrected in SP1, but should in SP2. There is a thread on the subject in the Nios forum.
Daixiwen describes the problem well. Below is the info I received from Altera tech support. The workaround corrected the problem for me.
> This is a bug of Nios II flash programmer tool v9.0. The behavior of this bug is that NiosII on Cyclone III does not boot up from EPCS if you
> programmed SOF and ELF with v9.0 Flash Programmer.
> The workaround:
> replace 90\nios2eds\bin\sof2flash.jar with 81\nios2eds\bin\sof2flash.jar
