Counters
I need help at writing counters in hdl.
The Altera Coding Guidelines suggest to code "out <= out + (count_up ? 1 : -1);"
instead of "out <= count_up ? out + 1 : out - 1;"
1.) How do I write the code, if I need to increment in certain states of a fsm?
2.) How do I write the code if I need to load certain values in certain states?
At the moment I simply write it in this way:
signal cnt : integer range 0 to 1024;
(IEEE 1076.6 says: "INTEGER range 9 to 10” should be synthesized using an equivalent vector length of 4 bits")
1.
case state is
when... =>
cnt <= cnt + 1;
when... =>
cnt <= cnt + 1;
when... =>
-- cnt <= cnt + 1;
end case;
Is this style better (is it similar to the altera suggestion)?
case state is
when... =>
cnt_tmp <= ONE;
when... =>
cnt_tmp <= ONE;
when... =>
cnt_tmp <= ZERO;
end case;
cnt <= cnt + cnt_tmp;
Will the RTL viewer instantiate a counter primitive if I write correct code?
TIA
Axel
Scenario# 1 is "asking" for three adders. The synthesis tools will most likely recognize that they are the same and merge them. Scenario# 2 is "asking" for one adder and a multiplexer driving cnt_tmp. The multiplexer will be (probably 32 bits) wide at first, then collapse rapidly due to all of the constant inputs. # 2 is better than# 1 because it more closely resembles the best hardware implementation. There is less chance for something to go wrong.
An even better implemenation is to build a standalone counter, with 1 bit increment and decrement control signals. Use the state machine to drive these control lines. This gives the tools absolutely no chance to make a mistake.
