21592 Discussions
bidirectional pin simulation for serial I2C
I have problems with bidirectinal pin simulation for serial comunication,
problem is there that simulator didn't show writes to SDIO inout pin and also don;t show read from this pin
I created test software wear I write some data to parallel-serial converter which sends serial data to SDIO pin and at the same time second logic-> serial to parallel converter reads data form SDIO line and show result, to show that parallel-serial logic work I inserted aditional output signal S_ouT were I can see that all is working, but on SDIO and SDIO~result are no signals.
how to set up this inout signal ??
here is .vwf file
https://www.alteraforum.com/forum/attachment.php?attachmentid=189
and here is simulation result
https://www.alteraforum.com/forum/attachment.php?attachmentid=188
I also read previous topic where was about bidirectional IO simulation but there was no useful information, I also read quartus handbook about simulating bidir IO and did all I can, but no results.
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity SPI_test is port(clk,LD,Ren,OE : in std_logic; Data : in std_logic_vector( 7 downto 0); SCK : out std_logic; SDIO : inout std_logic; parallel_out : out std_logic_vector( 6 downto 0); T_enT,LD_T,S_ouT : out std_logic ); end SPI_test; architecture SPI_test_arhitektura of SPI_test is signal timer,tmp :STD_logic_vector (7 downto 0); signal Timer_parallel : std_logic_vector ( 2 downto 0); signal Rdone,Timer_start, Timer_end, T_en,t_end, sdio_out, sdio_in : std_logic; component serial_paralel is port(CLOCK_16,Ren, SDIO : in std_logic; parallel_out : out std_logic_vector( 6 downto 0)); end component; begin process(clk) begin if rising_edge(clk) then if LD ='1' then tmp <=data;T_en<='1'; else tmp(7 downto 1)<= tmp(6 downto 0); end if; end if; end process; Sdio_out<=tmp(7); -- serialsignal that gows to bidir IO S_ouT<=tmp(7); -- Test signal for serial output --Altera code for Bidir IO setup PROCESS (oe, SDIO) -- Behavioral representation BEGIN -- of tri-states. IF( oe = '0') THEN SDIO <='Z'; sdio_in <= SDIO; ELSE SDIO <= sdio_out; sdio_in <= SDIO; END IF; END PROCESS; -- serial-parallel logic code block initialization Serial_in : serial_paralel port map(CLOCK_16=> clk,Ren=>Ren,SDIO=>SDIO_in,parallel_out=>parallel_out); end SPI_test_arhitektura;
I just tested this bidir pin code on my cyclone II dev.kit and it looks like bidirectional IO works, but simulator still don't work.
I think I will use for testing separate single output pin that will show oputput signal.
Hi Epis,
IMO problem is that VHDL simulator can't handle the 'Z' state. In real world , I assume that your SDIO pin is pullup'ed. There is a way to simulate this behavoiur in VHDL, you should use 'H' state (instead of 'Z') , which stand for 'Weak one' . The VHDL resolution function will then , for example, handle the case where an external '0' is applied on your SDIO 'H' state : in this case, the result would be '0'.
More help here : http://www.csee.umbc.edu/help/vhdl/misc.html
I used this to simulate an I2C bus transaction (SDA and SCL are also bidir lines), it works nice, at least using Modelsim simulator.
Warm regards.
For me it is strange, that you perform read and write to SDIO at the same time. I was using bidirectional pins. VHDL description looks like this:
IO <= output when OE = '1' else (others => 'Z');
Controlling the OE signal you can change the direction of IO pin/bus. As for simulation, you can observe data out , but reading from IO is practically impossible.
