21608 Discussions
Custom Instruction examples
I have created a set a custom instructions that demonstrate the various different types of custom instructions:
here is a quote from the intro in my tutorial:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Introduction
      ... this tutorial came bundled with several custom instruction examples which cover many different types of possibilities; such as, internal registry options, I/O options, and stalling options.  Examples below use a multiply accumulate (MAC) example from a basic instruction to one that takes advantage of many sophistication options.  A MAC is an operation which takes an input and multiplies it with its current value and then accumulates it.  The basic functionality of a MAC can be found in an included custom instruction user guide on page 1-11.  A Taylor series calculator and a “blinker” custom instruction that interacts with the LEDs are also included.  The Taylor series calculator can be used to approximate functions while the LED blinker demonstrates IO with custom instructions. ...[/b]
--- Quote End ---
Unlike many other custom instructions, some of the ones in this bindle are non-stalling, which speeds up computation, and some that are IO capable.
Note: with the Altera custom instruction guide the file size was too large. So, you can find it at
http://www.altera.com/literature/ug/ug_nio...instruction.pdf (http://www.altera.com/literature/ug/ug_nios2_custom_instruction.pdf)
The tutorial is awesome! Thanks a ton!
--- Quote Start ---
originally posted by rdturner@Sep 21 2005, 03:21 PM
i have created a set a custom instructions that demonstrate the various different types of custom instructions:
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
introduction
      ... this tutorial came bundled with several custom instruction examples which cover many different types of possibilities; such as, internal registry options, i/o options, and stalling options.  examples below use a multiply accumulate (mac) example from a basic instruction to one that takes advantage of many sophistication options.  a mac is an operation which takes an input and multiplies it with its current value and then accumulates it.  the basic functionality of a mac can be found in an included custom instruction user guide on page 1-11.  a taylor series calculator and a “blinker” custom instruction that interacts with the leds are also included.  the taylor series calculator can be used to approximate functions while the led blinker demonstrates io with custom instructions. ...
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=9877)</div>
[/b]
--- Quote End ---
Very Very good stuff.
longshot
