21602 Discussions
HW multipler custom instruction
Maybe following is too easy or too small to give the name IP http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Custom instruction that implements aprrox the same algorithm as the nios library for processors without dedicated multiplier.
Some benchmarks I did with :
int r; volatile int* pr = &r; //prevent optimalisations for (int a = -1000; a < 1000; a++)  for (int b = 1000; b >-1000; b--)  //count backwards : prevent optimalisations     *pr = a*b;
1. Without cutom instruction : this takes about 22.4 seconds at 50Mc with the standard NiosII
2. With the custominstruction in the mulsi function : 4.3 seconds (without frame pointer stuff)
The compiler made this :
__mulsi3:     custom 13, r2, r4, r5     ret
3. With the custominstruction inlined (without the additinal function call and ret instruction) : 2.4 seconds.
Unforunatly, I had to inline it inside the loop, I was not able to get the mulsi function inlined by the compiler.
If someone has suggestions, let me know
I think it is approx 280 LE&#39;s ( this was the difference when I added to an already existand custom instruction), maybe there is some extra overhead somewhere.
See also top of the verilog file for info.
Stefaan
Usefull for somebody? Any comments or improvements?
Stefaan
Hello Stefaan,
I’m interested in your code but until now I hadn’t enough time to evaluate it.
Thanks for your work,
niosIIuser
good boy !
custom_mul.v can not download now?
Where can I to found it?
Thanks!
--- Quote Start ---
where can i to found it?
thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16648)
--- quote end ---
--- Quote End ---
It seems to be a problem with the forum, I can&#39;t also.
Maybe some forum supervisor can?
Stefaan
--- Quote Start ---
originally posted by svhb@Jul 5 2006, 02:29 AM
it seems to be a problem with the forum, i can&#39;t also.
maybe some forum supervisor can?
stefaan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16653)
--- quote end ---
--- Quote End ---
Thanks!
Can you send it to me with email(chenm003@163.com)?
I&#39;m interest for this small multipler, it is the smallest than my found.
It would be interesting to see how this holds up agains the Cyclone II embedded mult.
how do i set a darn avatar on this board? ...i&#39;ll keep on traveling as always
--- Quote Start ---
originally posted by jdhar@Jul 5 2006, 08:49 PM
it would be interesting to see how this holds up agains the cyclone ii embedded mult.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16675)
--- quote end ---
--- Quote End ---
It will show up rather slow. Never tried to beat internal multipliers.
