Programmable Devices
21592 토론
Cyclone 10 GX requires Pro license
명예로운 기여자 II
4,660 조회수
I was a bit surprised that the new entry level family requires a Quartus Pro license (the GX version).
The older Cyclone GX families could be built using the Lite version.
Is this something which will persist?
The Xilinx Vivado WebPack supports Artix7 devices with 200kLEC's and 16X 6.6Gbps transceivers.
0 포인트
11 응답
명예로운 기여자 II
3,212 조회수
Cyclone10 GX is supported in Quartus Prime Pro without any License.
Refer to Quartus download page below.
http://dl.altera.com/17.1/?edition=pro&platform=windows&download_manager=dlm3
Cyclone 10 GX device support Part 1 (FREE, no license file required)
Size: 2.3 GB MD5: B580CE388353D676FAFEF693C57C70C2
Cyclone 10 GX device support Part 2 (FREE, no license file required)
Size: 3.0 GB MD5: 58C5653666D003F6967919DA68926E20
Also for full comparison among Quartus versions refer to link below.
https://www.altera.com/products/design-software/fpga-design/quartus-prime/download.html
arslanusman2003
(This message was posted on behalf of Intel Corporation)
0 포인트
명예로운 기여자 II
3,212 조회수
But the Pro version requires a license? Or are you saying that the device files might be installed into the lite version, or that the pro version can be run without a license if only the 10GX devices are used?
0 포인트
명예로운 기여자 II
3,212 조회수
--- Quote Start ---
arslanusman2003
--- Quote End ---
That's not what the O.P. was complaining about. Quartus Prime Pro costs $$$ and is the only version that supports Cyclone10 GX.
Quartus Prime Lite (free) and Standard ($) support Cyclone 10 LP, but not GX. So if you want/need to use Cyclone 10 GX you have to pay $$$ for the software to do it.
0 포인트
명예로운 기여자 II
3,212 조회수
The Intel Cyclone 10 GX device support is available for free in the Pro Edition software.
You can download the Quartus Prime Pro Edition, install Cyclone 10 GX device support and start using it.
arslanusman2003
0 포인트
명예로운 기여자 II
3,212 조회수
Yes, I guess the Lite version only supports the basic few devices for free. You would need to buy the Pro edition which will have support for the C10GX for free. The other devices require a paid subscription. In short, If you need to work on GX devices get the licensed version of the software. That's Intel,s policy.
0 포인트
명예로운 기여자 II
3,212 조회수
I'm still a bit confused whether a pro license has to be purchased or if it can be used for free with the Cyclone 10 GX. I installed and tried to build a small LED flash design. But when I tried to build I got:
Internal Error: Sub-system: DCALC, File: /quartus/ddb/dcalc/dcalc_bcm_modules_cache.cpp, Line: 116 Could not load pdb file - /tools/altera/quartus/v17.1.0.240_pro/quartus/common/devinfo/cyclone10gx/ddb_cyclone10gx_io_48_3v_tile-ff-3-0-hs_model_debug Stack Trace: 0x1129c9: DCALC_TIMING_NETLIST_MANAGER_IMPL::load_model(char const*, bool, DCALC_TIMING_DB_VERSION_ENUM) + 0x49 (ddb_dcalc) ... The file above is not in the installation. The closest match is files named ddb_cyclone10gx_io48_dr_clock_buffer*
Does that mean that it's not supported?
0 포인트
명예로운 기여자 II
3,212 조회수
The Quartus Lite versions do not support the GX devices. You cannot install devices that are not supported by the Lite version also. For all other devices not supported in the Lite version, you need to get the Paid Standard or Pro editions.
https://www.alteraforum.com/forum/attachment.php?attachmentid=14525
0 포인트
명예로운 기여자 II
3,212 조회수
--- Quote Start ---
--- Quote End ---
This is a known issue for Quartus Pro 17.1 with Cyclone10 device family installed.
Please refer to KDB for the workaround, this will be fixed in future release of Quartus.
https://www.altera.com/support/support-resources/knowledge-base/tools/2017/internal-error--sub-system--dcalc--file---quartus-ddb-dcalc-dcal.html
arslanusman2003
0 포인트
명예로운 기여자 II
3,212 조회수
--- Quote Start ---
--- Quote End ---
Allow me to clarify your confusion.
for Cyclone 10 -LP yes you will use Quartus Lite Edition.
for Cyclone 10-GX use Quartus Pro Edition, you can download it for free and install it in your system and start using Cyclone 10 GX device.
For Arria 10 and Stratix10 device you need to purchase a License.
arslanusman2003
명예로운 기여자 II
3,212 조회수
--- Quote Start ---
--- Quote End ---
Update ... looks like I stand corrected ... in this document:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/po/ss-quartus-comparison.pdf
Footnote (2) is: 2. the intel cyclone 10 gx device support is available for free in the pro edition software.
so it looks like indeed you can download the Pro version and use it for free, but ONLY for the Cyclone 10 GX device family.
0 포인트
명예로운 기여자 II
3,212 조회수
Thank you for making that clear. I did a test, including the Arria 10 devices, and now it works. Thanks!
0 포인트
응답
