21611 Discussions
Cyclone 10 LP GND pins internally connected?
stomat
I have design with a 10CL006YE144I7G which works fine in hundreds of devices but in few number of devices the FPGA stopped loading the configuration from the flash. I removed the FPGA from the pcb for measuring purposes and I realized that the GND are connected to each other. I compared it with a new FPGA and it's the same. Is this correct that these pins are not connected internally? Is there a documentation whrer I can find further informations?
Labels (2)
AqidAyman_Intel
Yes, you are correct. As per my understanding, the GND pins are not connected internally as per in the Pin Connection Guidelines of Cyclone 10 LP, it mentioned to connect all the GND pins to the ground plane.
Reference:
https://www.intel.com/content/www/us/en/docs/programmable/683137/current/supply-pins.html
AqidAyman_Intel
Reference:
AqidAyman_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you.
It will be appreciated if you can fill the evaluation survey based on my support to your question.
Thanks a lot!
FvM
seriously I don't understand the original post. It says "I realized that the GND are connected to each other" and continuous asking "Is this correct that these pins are not connected internally?" In my understanding, the statements are contradictory.
stomat
thanks for your reply. I made a mistake in my original post, sorry for that. I wrote " I removed the FPGA from the pcb for measuring purposes and I realized that the GND are connected to each other. " but it should have been "I removed the FPGA from the pcb for measuring purposes and I realized that the GND pins are NOT connected to each other. ". I hope my question is now clear.
