21615 Discussions
Cyclone 10 LP JTAG interface voltage
_Andrey_
Hello!
In Cyclone 10 LP FPGA Evaluation Kit Board schematic JTAG interface of Cyclone10LP is power by filtered version of 2.5V supply. Is it nessesary? Can I use not filtered 2.5V for JTAG interface?
YuanLi_S_Intel
As per our pin connection guidelines, it is recommended to use a filter if you are sharing a power rail.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-10/pcg-01021.pdf
You may choose not to use a filter but you need to evaluate the power and signal integrity and do it at your own risk.
Thank You.
YuanLi_S_Intel
Thank You.
